Learn more
Property Manager (blank fields?)
Hi all in the archicad demonstration video:
https://helpcenter.graphisoft.com/videos/archicad/archicad-21-new-features/archicad_21_autotext_labe...
it demonstrates uses the property manager to add a fire rating to a wall in the example/tutorial video.
however in my archicad file there are absolutely no property fields available?
i would need to go through and generate them all from scratch.
normally archicad provide a starting point with fields you can add to or modify to suit your project, is there a standard property list file that I can import general fields as a starting point? also I would have thought it might be good to incorporate this from the beginning as a way of standardising the fields so they they can simply be selected ie when following tutorial videos.
im not sure if it is simply because my archicad template file was originally a v19 file or..?
Also im not sure why we have the classification manager and also the property manager do they not both do a similar job to one another?
2 Replies 2
I can't answer the first question, but I have spent some time trying to wrap my head around around the Classification/Properties scheme. The Classifications are like the "high level" pigeonholes, which allow a wall to be an interior wall, an exterior wall, millwork, or a piece of art. Specific properties can be assigned to that specific classification pigeonhole depending on what it is, so you don't have to see all properties -- all the time. A wall which is an exterior wall is likely to have only a certain set of relevant properties, whereas a wall which is functioning as a crown molding (and has that set as its classification) can have completely different ones.
Richard
AC26 (since AC6.0), Win10
runxel
On migrated files newer stuff will be missing.
Just open the OOTB template and get all the 'default' properties out of there.
