Purge nested elements
Paopao
Is there a comman in Archicad similar to "purge nested elements" in Autocad? what do you do when you receive a drawing with nested lines? Don't tell me you have to delte them one by one....
thanks
PP
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
5 REPLIES 5
not sure if this is exactly what you're after, but there is a "check duplicates" command in the edit menu that lets you find and delete multiple copies of elements.
There is also the line consolidation tool that can merge overlapping lines that aren't exact duplicates.
I am assuming by "nested" that you mean overlapping or duplicate.
If by "nested" you mean "grouped" then just use the enable groups button and delete all the grouped lines in one go.
But like Kombibob I think you mean overlapping.
Paopao
Yes guys, I mean overlapping.
I can't find the "check duplicate" in Edit Menu though. I am using Arc 16 nowadays.
David Maudlin
Paopao:
Check Duplicates is a Goodie (not part of the standard installation), so in ArchiCAD go to Help > ArchiCAD 16 Downloads to be taken to a web page where you can download this Goodie.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Paopao
Thanks David!
