2012-06-09
12:57 PM
2023-05-24
12:56 PM
Rubia Torres
2012-06-10 10:40 AM
2012-06-10 12:21 PM
I'm assuming you are publishing the modules from a master file rather than hotlinking PLN files (if not you should be).not sure If I got what you meant here, will tell you my setup .. a master BIM server shared project containing linked .mod files,those are ( 1-external shell walls.mod "the reason it is saved as mod is that it is repetitive also in the floors) , 2-each repetitive unit.mod,etc.. ) everything else is done on the master BIM server shared project
1. Use an exterior wall layer in the unit plans master so you draw and dimension your complete unit plans in the master. Turn off this layer (and any others you don't need) in the layer combo used to publish your modules.yes, this is what I am doing, and no I can't hide that layer because it will be the one shows the dimensions of the rooms (e.g: the dimensions of the rooms that have external walls).
2. One way around this is to make custom doors and windows for the project. I have set this up for several firms but it can be a bit complex depending on your needs. It's probably only worthwhile if you have multiple buildings using the same door and window schedules.I think custom doors and windows are out of question for my case, however I am curious on the part where do you say :
If the unit plan modules are in a single master file (as they should be) you can use the scheduler to quickly change all instances in all units at once. Exactly how to do this will depend on how you set things up. The easiest is to use the ID for the door/window type and use this as your sort field.
2012-06-10 06:29 PM
2012-06-13 05:47 PM
