Question about working with Worksheets
I inserted an XREF into an Independent Worksheet within a Module file.
I left the MOD file...when I came back the Worksheet is gone.
Vanished...is this supposed to happen?
How do I get it to remain in place for further use?
12 Replies 12
Use a PLN file. Think of a MOD file as a saved clipboard. It does not contain views, etc etc... When you open a MOD, it merges itself with the settings for the last open project. It then appears that you are working on a complete project - and in fact you can save what you are doing as a PLN. But, if you save as a MOD, you are only saving the story information, or in the case of save-selected-as-module, the selected elements.
I probably should have mentioned that these MOD file are apartment units to be Hotlinked into a Building Plan PLN file.
Is using a PLN file going to adversely effect my ability to Hotlink these drawings into that Building Plan?
That's an appropriate use of MOD files. You can hotlink from PLN as well.
Given the original question - concerning an xrefed drawing in a worksheet - I believe you might want to examine using a PLN file and within that file create a Publisher set which publishes (saves) your apartment units as MOD files.
Rather than two pln files, I do all of this within one file, where there are specific views for the shared elements (common walls for a high-rise, common room layouts for hotel, etc) which are published as mod files which are hotlinked back into the file. Hotlinking back to the pln file in that case (vs publishing/saving mod files) is troublesome because you do not have control over which elements are hotlinked. The publish / update hotlinks cycle is pretty easy once the file and hotlinks are set up.
Others with more experience in this area probably have better ideas.
Laura Yanoviak
This is what we do; however, unlike Karl, we use a separate PLN file (so as not to "put all of our eggs in one basket", so-to-speak). Also, with Teamwork, sometimes it's just easier to use separate files, especially if you have a large team.
I cannot find a lot of information on the worksheets, so I am going to post here.
Is there a way to copy worksheets from one .pln file to another?
Sort of like a copy paste?
Thanks in advanced.
I think this is not possible to do directly.
However, you can create a new independent Worksheet in your target file, then copy everything in the source Worksheet in the source file and paste them in the target Worksheet in the target file.
Rafal SLEK
Do You mean this?:
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Tahoe/Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/
//MSI AMD Ryzen AI 9/2.5GHz/32GB/Nvidia RTX 5070 Ti/Windows 11 Pro
//ArchiCAD Collaborate
YES!!
That is what I was trying to do with both the PLN files open, but was missing the drag and drop step.
Thank you Rafal!
vfrontiers
While you are showing this working for LAYOUTS, I don't believe it will CREATE a Worksheet from one file to another. In fact the Project Map is not even available on the left had side (or the right hand side for that matter).
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
