‎2007-12-18 01:13 AM
‎2007-12-18 01:31 AM
Ledbetter, wrote:Use a PLN file. Think of a MOD file as a saved clipboard. It does not contain views, etc etc... When you open a MOD, it merges itself with the settings for the last open project. It then appears that you are working on a complete project - and in fact you can save what you are doing as a PLN. But, if you save as a MOD, you are only saving the story information, or in the case of save-selected-as-module, the selected elements.
I inserted an XREF into an Independent Worksheet within a Module file.
I left the MOD file...when I came back the Worksheet is gone.
Vanished...is this supposed to happen?
How do I get it to remain in place for further use?
‎2007-12-18 01:59 AM
‎2007-12-18 02:55 AM
Ledbetter, wrote:That's an appropriate use of MOD files. You can hotlink from PLN as well.
I probably should have mentioned that these MOD file are apartment units to be Hotlinked into a Building Plan PLN file.
Is using a PLN file going to adversely effect my ability to Hotlink these drawings into that Building Plan?
‎2007-12-19 05:12 PM
Karl wrote:This is what we do; however, unlike Karl, we use a separate PLN file (so as not to "put all of our eggs in one basket", so-to-speak). Also, with Teamwork, sometimes it's just easier to use separate files, especially if you have a large team.
I believe you might want to examine using a PLN file and within that file create a Publisher set which publishes (saves) your apartment units as MOD files.
‎2009-06-03 01:48 AM
‎2009-06-03 01:44 PM
‎2009-06-03 10:40 PM
Josh wrote:Do You mean this?:
Is there a way to copy worksheets from one .pln file to another?
Sort of like a copy paste?
‎2009-06-03 10:43 PM
‎2009-06-04 06:38 AM
