2004-05-10
12:11 AM
2023-05-26
03:26 PM
Rubia Torres
2004-05-10 07:06 PM
Peter wrote:Not that I know of ... however, it would be good to know the purpose of your pasting into the plan; maybe the same result that you want can be achieved in PlotMaker by linking the view?
Is there some way of making AC use a wider range
of fill color tones when copying and pasting as lines and fills?
2004-05-10 08:09 PM
2004-05-10 09:06 PM
2004-05-10 09:55 PM
2004-05-11 08:24 PM
Peter wrote:Depends on the system; whatever it is, if the 3D window is in OpenGL, it is an image (just tried today, and it works - now if we only can fathom why it does not work for John Cassell!) and if the Analytic view it is a vectorial file, that is to say PMK, that will take longer to generate3 but can be set to proper scale.
Your idea of a direct link of the 3D window to PlotMaker solves the practical problem.
What appears in PlotMaker is a *.Pict type file isn't it?
2004-05-11 08:35 PM
