2013-02-28 08:17 PM
2013-02-28 08:43 PM
2013-02-28 08:44 PM
2013-02-28 09:04 PM
ejrolon wrote:Thanks so much!!!
Read in the manual about "Modules".
Basically you will save a Mod from the "original" and then place the modules on your site. Then if you edit the original module it will update all others.
2013-02-28 09:06 PM
s2art wrote:
All grouping does is make the elements easier to select in one go. If you (suspend groups and) alter anything it is only that one instance that gets changed, not other copied groups.
You want to investigate Hotlinked Modules (a selection of objects or elements in a distinct MOD file, which can be updated through multiple instances). A MOD file is basically a mini PLN, but with just the relevant elements.
An alternative, but probably not what you're after in this case, is creating an Object.
Lots of advice around this forum if you do a quick search for either of those terms.
Hope this helps.
Edit - Ha ha, I obviously type too slow, and say too much, Eduardo.
