Quit causes crash and bug reporter
TDabney
Just yesterday I started having some weird behavior - namely every time I quit a session of ArchiCad, it crashes and starts the bug reporter. I have trashed all the preference files, done some New & Resets etc... Is there anything else I could try?
Thanks, Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
4 REPLIES 4
Eduardo Rolon
Options to try:
1) Use disk utility to repair permissions
2) Do a new and reset in AC to see if there is a problem object or setting
3) If it is a project that is giving you problems, it might be a problem library part or slab/roof/terrain that have invalid holes
The last time I had this happen to me was after drawing a slab and using the magic wand to remover a portion of it. For some reason AC then crashed either when building an elevation or when closing. This was in AC8.1
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
TDabney
Well, I tried a bunch of things - none of which worked - so I uninstalled and reinstalled AC9 and everything seems to be working fine. I just need the rest of the day to reconfigure all my keyboard shortcuts, pallet layouts and toolbar customization! Oh well.
Tom
macOS 12.7
Apple M1 Max
ArchiCAD 26/27
Eduardo Rolon
Remember that you can export all your settings to a file so that if you need to reinstall then you can import them and avoid having to do them all over again...
AC29 US/INT -> AC08
another Moderator
TDabney
DOHHH! Oh well, maybe next time - although I did want to make a clean break from the "corrupted" version and start afresh.
Thanks, Tom
macOS 12.7
Apple M1 Max
ArchiCAD 26/27
