ROUND BEAM intersection
plz solve my problem
i used cylinderical basic shape for round beam
i have two beams intersecting in the form of T
i tried union in solid element operation to get good intersection in section view but i failed i could have easily drawn it in autocad
how do u do it in archicad
14 Replies 14
take it
ishpalsingh,
This image is a lot clearer.
You are apparently using a pole framing building system with
standardized parts such as axis connector and knee connector.
I am unfamiliar with these connectors as I have never seen
a building made with this particular building system.
I did a search on the Internet using key words like
"HS Unilog Rafter" and "Knee Connector" to try to educate myself
but could not find any reference to this building system.
I would like to try to help you model your building in Archicad
but I really need more information in order to do so.
If you could draw a detail showing the geometry
of this connector, it would help.
Thank you,
Peter Devlin
ishpalsingh,
I tried again on the Internet and found "Unilog".
It is a pole framing system and I might be able
to figure what these connectors are and therefor
how to model them in Archicad.
Peter Devlin
ishpalsingh,
I think I understand these connectors and they are very easy to make
In Archicad. You can either make the complete pole frame including
the connectors using TrussMaker or just make the connectors
using TrussMaker. Use the hollow section and circular profile.
The attached image is of a pole frame with connectors using TrussMaker.
Peter Devlin
thanx for helping i ll try & tell u
