We value your input!
Rafters.
tea lover
Jere
That usually happens to any object if the default settings have it higher than the current storey. If it's nonetheless at the proper height, the easiest solution is to simply right-click on the object and hit "relink home story". This allows you to change which storey it's on without altering its height.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
1 REPLY 1
Jere
