Railing Tool - Fixing Plate to stay horizontal
Andre_Steynberg
Hi all
Hope everyone is doing well.
On the railing tool in AC22, is there anyway to keep the fixing plate flat / horizontal regardless of the angle railing itself?
On the pic I've added the right hand side is correct, I would like the left hand side to also be horizontal instead of following the angle of the reference line.
Anyway to do this?
Andre Steynberg
Win 10 64-bit
AC27
The setting is not in the fixing section, but in the main post section.
If you want all of the bottoms to be horizontal, you can set for the railing (for both posts and inner post) as a whole.
Otherwise you can select an individual post and change the setting for just that post (you will have to convert the pattern to segment length to be able to select individual posts).
Andre_Steynberg
Barry
thanks for the reply.
Some experimenting later and it seems that option only works with both Associative options enabled (which I never do for some reason).
Both on now and working well, thanks again for the help
Andre
Andre Steynberg
Win 10 64-bit
AC27
It is the same for static rails as well.
I just checked in 24 and each post has top and bottom endings that can be parallel to slope, horizontal or perpendicular to post.
Barry
