gdford
Railing Tool for Curb and Gutter
Is there anyway to get the joints to grow together better?
Note attached pic
Thanks!!
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
9 Replies 9
Lingwisyer
Guru
I am assuming that is the result of a "corner connection". Depending on the alignment, which looks pretty simple, you maybe able to just use the edit mode to delete it.
Ling.
The connection type may be set to 'gooseneck'.
Try changing it to 'continuous' with no offset values.
gdford
YES !!! The problem was in the top rail connection settings. Now it works like a charm.
I had not drilled down to that setting. Thank-you so much.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Carstenem
This tutorial will explain this in a bit more detail.
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
AK3463
Hi, does anyone know if using the railing tool for adding associative curbs would work on a slab that is embedded into a mesh?
In the attached image the parking lot slab is embedded into the ground mesh. I'd like to add a curb around just the parking lot. When I try it only wants to select the ground mesh perimeter. When I turned off the ground mesh, it allowed me to select the parking lot, but it placed the curb at the original flat plan of the slab, and not its embedded height at the mesh.
Any ideas? Thanks!
Lingwisyer
Guru
Have you intersected the slab with the mesh?
If the perimeter of the parking area is a contour in the mesh or is a hole cut in the mesh (Solid Element Operation with the slab), then you can just magic wand the rail (curb) to that contour and it will follow the heights.
AK3463
Thanks Barry. The contours run through the parking area, so there isn't one at the perimeter. The parking area slab is intersected with the overall ground mesh, and then it's subtracted with upward extrusion so that the surface shows correctly. Any other thoughts?
You can create a contour around the parking slab.
Select the mesh, with the mesh tool active magic wand (space bar) on the slab perimeter.
You should get a dialogue asking if you want to create a contour or a hole (obviously you want a contour).
I think this will work even after an SEO - but I don't have Archicad running to test at the moment.
That will create a contour with heights set to follow the top surface of the mesh.
Now you can magic wand your railing to that contour.
