Railing tool newel post
Is there a way to add a custom top ending to a newel post? None of the five presents work for my design.
Guru
You can make your own post with the standard tools and save it out as a custom railing post, much like you can do with a door leaf.
Ling.
Guru
Ling.
Thank you, Ling. "Save as...railing post" had not updated on my work environment. That's exactly what I needed. Thanks again.
Ling.
