Railing tool problem
Hello all,
I'm a university student and I am having problems with the railing tool as its stuck blue. Probably a simple answer but i've asked all of my fellow students and we all have no idea on how to solve this. I have tried to override textures and that but it never changes from blue.
See pictures attached
Many thanks,
Ben
Change your Model View Options (MVO) from 'Schematic' to 'Full' for Railings.
In the Menu under Document>Set Model View> Model View Options and then under the Stair and Rail Options you should see the options for what to show in the 'Stair and Rail Detail Level in 3D and Section' Settings
Your Rail settings is most likely either set to 'Schematic' or 'Simplified' or it's 'Full' but with everything unchecked except the posts.
Change it to Full to show the full railing.
Yilin Pan
got stuck with the exact problem, thanks so much for the resolution!
