Railing - turn off handrail
If the top rail IS the handrail, how do I turn off the handrail like I can with railing selection 'invisible'?
I can only see 'Built-In Rail' for handrails. Is ArchiCAD forcing my railing to have a handrail?
In the upper right corner of the preview (under the "Segment" section) are "+ -" buttons. You can add or subtract railings with them.
Richard
AC26 (since AC6.0), Win10
Richard
Thanks Richard, two different ways of turning rails off......
You can also select any component (including any Rail) in the preview in the Railing Settings Dialog and press the BACKSPACE key or the DELETE key to delete it.
