ā2008-07-04
04:45 AM
- last edited on
ā2023-05-23
03:09 PM
by
Rubia Torres
ā2008-07-04 05:38 AM
ā2008-07-04 03:16 PM
meapl wrote:You may be interested in OBJECTiVE. It provides a timber and steel library, with tools for placing, cutting, and rotating members. You can draw and cut your beams directly into the section if you wish. And more to the point, it provides the size measurements you need. If you refer to the attached image, the object settings show the length of the beam at its greatest extents (irrespective of the end shaping).
How do you draw raked beams to pergola, ie what height do they pitch off because roof only gives your pitch, not highest point dimension. You can measure on section, but how do you accurately?
