I am trying to make a ramp as this image. As you can see I marked the corners with red. I want to fill those corners with same material as the ramp but I can only do it round with empty corners. I also uploaded the Archicad file.
Thanks in adavnce.
	Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz   3.19 GHz, 8.00 GB,  64-bit operating system, x64-based processor
