2006-01-19
06:14 PM
- last edited on
2023-05-25
06:19 PM
by
Rubia Torres
2006-01-20 07:19 PM
2006-01-20 11:06 PM
Josephus wrote:Small parts of walls (always on outside direction) called reveal. I'm not sure if anywhere they are still in use, but this construction method was used before new generation of Windows/Doors cames out. This is/was just simple universal cheap construction:
Can someone tell me what the peculiar looking IMO icon is for window placement as shown below? ....when I've used this insertion method it creates a weird wall inside of the window.
2006-01-21 12:37 AM
2006-01-21 12:41 AM
2006-01-21 11:42 AM
2006-01-21 10:05 PM
Petros wrote:Is the "empty" fill the same as the transparent background you're referring to?
The empty opening should be wider than the casement window (2 x reveals) and also do not forget to give it a transparent background fill (2d settings) so that you can see the casement window on plan.
Petros
2006-01-21 11:20 PM
2006-01-22 04:17 AM
2006-01-22 12:32 PM
2006-01-23 12:34 AM
