Reflected Ceiling
Which tool should I use for reflected ceiling
TomWaltz
The Slab Tool works well for me.
Tom Waltz
Aussie John
It is too bad if you have a sloping ceiling because the roof tool shows the top of the slope in 2D when you actually require the bottom view of the slope. The problem becomes worse as the "roof" gets thicker.
I wish GS would give the option of which side to view from. BTW I put this as a poll wish some time back but dont think any one voted for it. I wonder how people work around this???
Cheers John
[/size]
Rafal SLEK
There is a new option for Model View Options for GDL Objects in AC11 -
Story Viewpoint Type:
- Floor plan
- Ceiling Plan
If standard ArchiCAD tools such as Slab, Profiled Walls or Beams are not so good for Your work check Cigraph plugin called ArchiPanel:
http://www.cigraph.it/cigraph/pagetrans.do?action=current_product&prodotti_id=16&lang=en
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD 28/Twinmotion 2024
