giza
Wall-Slab intersections priority in section/elevation view??
Hi all,
can anybody provide solution to presentation of intersections of wall and slab composites on the section window, or maybe better answer is this possible?
this intersection priority of composite walls works perfectly in floor plan window but why is this problem in section, also the beam section fill will not intersect with slab composite fill ... any idea ?
thnx in advance.
Gezim Radoniqi | Architect | BIM Manager @ 4MGroup
ArchiCAD user since version 6
AMD Ryzen 3950X CPU, 64 GB RAM, NVidia RTX 3060 12GB
3 Replies 3
Djordje
giza wrote:
Hi all,
thnx in advance.
Can you post a screenshot?
Normally, walls and slabs should precisely touch - not intersect in space. Adding the beams into the equation makes things a bit more complicated, so let's keep on talking after your screenshot ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I am having the same problem.... If columns overhead the walls in plan, why slabs dont overhead walls in sections ?
TomWaltz
The plan has a bunch of fake graphic methods. The section is a true cut through the model.
Solid Element Operations will give you what you want.
Tom Waltz
