Removing Storey Lines In Section
Does anyone here know how you can remove those damn storey marker lines that Archicad always draws for you in Section?
I've been to the Section Tool Settings but can't for the life of me find the command to turn those damned lines off.
Robert
undefined
13 REPLIES 13
KeesW
I was messing around with storey lines in sections yesterday and discovered an annoying defect. When storeys are close together, AC10 makes a real mess of overlapping storey labels. It would be better if storey lables included the option to put story name and level on the same line - rather than being above and below the line. It would take up less vertical space and might fit better where levels are close.
AC10 is full of implementations that nearly work - but produce ugly results when situations are not ideal.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
Not specific to your request, but applicable: VOTE
Stephen Dolbee
A little late, but also right-clicking in the section window lets you turn off storey lines.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Thanks, Steve!
