Render issue?
Hi, I'm having some difficulties seeing a 3D picture of a series of portals I am constructing. At some point the portals vanish into thin air in the 3D window, while they are still there in the floor plans. Is it something in the settings I need to adjust or am I missing something else? Any tips are appreciated?
I'm using archicad 11 on a mac.
Thanks,
Peter de Ruijter
The Netherlands
P.S. I'm attaching a jpg of what I'm seeing. Some beams don't completely vanish, other are completely gone. The dimension of the beams are height 500 mm, width 100mm. In some cases I only see a surface in the 3D window and not the 100mm width of the beam. ..... strange....
9 REPLIES 9
Ted Taylor
Check to see if you have duplicate beams occurring in the same spot. Archicad tends not to like that kind of alternate reality.
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
Thanks Ted,
I had some wall elements of different proportions, however also in this parallel patern, in a hidden layer. I removed these, and now it shows perfectly!
Thanks a lot.
Peter -
Ted, Check to see if you have duplicate messages occurring in the same thread.
(I deleted the duplicates.)
Ted Taylor
Oops! Thanks for clearing the debris.
Ted Taylor
Atlanta, GA , USA
OS10.14.2,
Latest Archicad 22
Excellent. So now I look silly, instead of Ted. Oh, well.
Erika Epstein
Coming from someone whose avatar shows his family playing Twister?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Dwight
Ooooo. Burn.
Dwight Atkinson
Oooo. Meow!
