Render issue?
Hi, I'm having some difficulties seeing a 3D picture of a series of portals I am constructing. At some point the portals vanish into thin air in the 3D window, while they are still there in the floor plans. Is it something in the settings I need to adjust or am I missing something else? Any tips are appreciated?
I'm using archicad 11 on a mac.
Thanks,
Peter de Ruijter
The Netherlands
P.S. I'm attaching a jpg of what I'm seeing. Some beams don't completely vanish, other are completely gone. The dimension of the beams are height 500 mm, width 100mm. In some cases I only see a surface in the 3D window and not the 100mm width of the beam. ..... strange....
9 REPLIES 9
Ted Taylor
Check to see if you have duplicate beams occurring in the same spot. Archicad tends not to like that kind of alternate reality.
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
Thanks Ted,
I had some wall elements of different proportions, however also in this parallel patern, in a hidden layer. I removed these, and now it shows perfectly!
Thanks a lot.
Peter -
Ted, Check to see if you have duplicate messages occurring in the same thread.
(I deleted the duplicates.)
One of the forum moderators
Ted Taylor
Oops! Thanks for clearing the debris.
Ted Taylor
Atlanta, GA , USA
OS10.14.2,
Latest Archicad 22
Excellent. So now I look silly, instead of Ted. Oh, well.
Erika Epstein
Coming from someone whose avatar shows his family playing Twister?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Dwight
Ooooo. Burn.
Dwight Atkinson
Oooo. Meow!
