Slab will only show outline in 3D
I recently installed ArchiCAD 12. I was using 11 for a year with good success. However, I can no longer view slab materials in 3D. Slabs will only show up as black outlines. Everything else shows materials. I am not in wire mode. I've tried different model view settings. I have looked at all 3D settings I can find. I've installed all of the new Hotfixes. Noting is working. Can anyone please help!
Thank you,
Kristy
2 REPLIES 2
Erika Epstein
Sounds like the layer the slab is on was changed to wireframe display in the Layer settings box ctrl/cmd+L
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thank you so much Erika! I did not realize you could just put one layer on wireframe.
Kristy
