Rendering problems..
Hi!
When I`m using LightWorks Rendering Engine, the texture image on the 3D will not show (wall sidings). All I can see is just a color, and not the siding texture.
But, when I`m using Internal Rendering Engine, then it shows.
What do I have to do?
Dwight
1: turn on textures in LightWorks - PhotoRendering Settings dialog.
2: In reviewing the material surface, make sure that the texture map used in the Internal Engin and OpenGL is ALSO employed by LightWorks.
Study the material dialog as attached.
The quickest way to transfer qualities from the Internal Engine to LightWorks is to press the "Match Internal" button
Dwight Atkinson
Thats great Dwight 🙂)
I´m learning something new every day..
