Renovation Filter - I can't find the options box or palette
Kathryn W
Help please!
Archicad Help 15 says that the Renovation Filter options box is located at: Document > Set Renovation Filter > Renovation Filter Options
Likewise, there is a Renovation Filter palette, located at:
Window > Palettes > Renovation Palette
Neither of these are located on my drop down menus. I am using 15 and the renovation filter is there, as I can change the filter through my quick options palette or my view settings but I can't view the actual renovation filter options or palette.
Is this a bug or is my archicad not working properly?
Kathryn
Archicad version 19
Windows 10
3 REPLIES 3
Are you using a non-standard Work Environment? If so, modify it accordingly, or try a standard WE.
Kathryn W
Thank you Stuart!!
I was using a WE that I had originally created in 14, I have now changed it so the Command Layout Scheme is set to Standard Commands 15 (instead of 14) and it is all showing as it should be.
That's made my day
Kathryn
Archicad version 19
Windows 10
That would do it. There was no Renovation filter in 14, hence no command / palette in that WE.
Glad to have helped.
