dtp81390 wrote:
I am having the same issues with my current project. Does anyone know how to fix this issue.
Perhaps you haven't changed the renovation filter to 'Planned Status' and it is still displaying it's override material?
Are you using the Cadimage doors maybe - it could just be a bug in the library part? Report it to them if you think it is.
I'm not sure it makes any difference, but check you are correctly indicating the outside of the wall when placing the door. The third click specifies which face of the wall should be considered the outside, as well as the opening direction. Use the 'Flip' button in the info box afterwards if the door should open inwards.
Hope that helps.
