2024-06-02
02:21 PM
2024-06-06
06:50 PM
Sorry if this appears to be a copy of my previous post, but I have realised that I did not ask the right question.
I would like to replicate the stairs as presented in the attached drawing, as this is what will be supplied by the stair manufacturer.
I am having problems getting the results I want from AC stairmaker.
Can anyone advise me the best way to replicate a stair like this? For example, AC doesnt want to give me 3 stairs on the turn and in the same manner.
Is there a way to magic wand a 2d outline if I draw out the dimensions of the staircase I want??
Thanks
Operating system used: Windows 10
Solved! Go to Solution.
2024-06-02 08:02 PM - edited 2024-06-02 08:06 PM
You can change the number of goings in afterwards in the petpallet menu.
2024-06-02 08:33 PM
Hallelujah ! Thank you very much for that very clear explanation, worked perfectly.
2024-06-02 08:34 PM
You're welcome!
2024-06-03 05:15 AM
Or you can set it in the stair settings before you place the stair.
