Replicate stair design
Strawbale23
Sorry if this appears to be a copy of my previous post, but I have realised that I did not ask the right question.
I would like to replicate the stairs as presented in the attached drawing, as this is what will be supplied by the stair manufacturer.
I am having problems getting the results I want from AC stairmaker.
Can anyone advise me the best way to replicate a stair like this? For example, AC doesnt want to give me 3 stairs on the turn and in the same manner.
Is there a way to magic wand a 2d outline if I draw out the dimensions of the staircase I want??
Thanks
Operating system used: Windows 10
AC26
https://www.zendsign.fr/
cuba
You can change the number of goings in afterwards in the petpallet menu.
undefined
Apple M1 Max 32 GB Ventura
AC27
4 REPLIES 4
cuba
undefined
AC27
Hallelujah ! Thank you very much for that very clear explanation, worked perfectly.
AC26
cuba
You're welcome!
AC27
Or you can set it in the stair settings before you place the stair.
Setup info provided by author
