mukster
Resizing the CMU block Pattern
Using Archicad 27 on a MAC platform,
US user here. I have a wall with a 16"X8" CMU pattern, but in the elevations, it's showing up as 32"x11". Any ideas on how I can get the fill to show up a 16"x8"?
aarkell
Depends on what settings your elevation is using. If the model display under elevation settings is set to "Surface, Color Fill", you'll need to make sure the fill associated with the surface is set to the correct dimensions. That would be changed here:
If the model display under elevation settings is set to "Surface, Texture Fill", you'll need to make sure the jpg associated with the surface is set to the correct dimensions. That would be changed here:
In both cases, you may want to duplicate the fill or surface before modifying just in case you have used the original elsewhere and it to remain the same at those previous locations.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
