!Restored: Problem with 3d window setings... i'm stuck
i just reinstalled my sistem everything a-ok untill..... i started archicad. i usualy use open gl in my 3d window setings... but ... after i reinstalled ... darn ... the 3d window while in opengl is a total black. everything is there as if i accidentaly click on a wall .. i can modify it ... but i can't see anything. anyone else stumbled into this? what on earth did i do wrong .. .it's not the first time i reinstall my sistem. 10x
4 REPLIES 4
Djordje
Check your video driver; this sounds like an incompatibility. Do a Rebuild after you open the 3D window, or just Redraw, and it should be OK.
Which ArchiCAD? Which platform?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
well archicad 8.1/ win xp.
barton 2500
geforce 4 mx
512 ram
mb epox something ..
hey .... pbm solved ... turns out i forgot to install the geforce ... hahahahah silly me. i feel kind of silly anyways. thanks dude. u'r the "bestestest"
Djordje
Works much better when switched on, huh? 😉
Djordje
HP Omen
