You must create a VIEW of the detail window with the proper layer combination (and other attributes) assigned.
So..
1. Open Detail
2. Set up Layer Combo
3. Assign Pen Set
4. Assign Proper Dimension Settings
In the VIEW MAP (not the Project Map), right click on the folder in which you want place this view and SAVE CURRENT VIEW...
You'll then NAME it something appropriate.
The only way to get back to this view is to open thru the VIEW MAP. That is actually the job of the VIEW MAP is to take and given window in your Plan File along with all those attributes and save it.
So. Project Map = Raw Windows. Clicking on an entry in the PROJECT MAP only switches windows
View Map = Raw Window + Layers + Pens + Dimensions + Scale, etc, etc, etc.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
