!Restored: Selecting in 3D by Find & Select, can not get it working
Why I can not select in 3D the same criterua that is selectable in plan?
4 Replies 4
TomWaltz
You should be able to.
Tom Waltz
Well it may be a bug,
I am tring to find my missing objects (do to new version) By Name. In Plan Find & Select finds them but not in 3D
TomWaltz
Since the object cannot be found, there's no way for Archicad to create them in 3D. As a result, they don't show up in the 3D window at all, so you could not select them.
Do you have the subset libraries loaded?
Tom Waltz
I do have the subsets but I chose not to use them but to replace all my objects with the same in the new version. Do not like carrying additional library for rest of my life. They are too heavy.
Thanks for the input.
