2006-05-02 04:19 PM
2006-06-17 06:10 PM
Dilbert wrote:I was referring to form•Z not Revit. Naturally all advanced programs will require considerable time to master, form•Z just seems to make it a bit harder with their non-standard approach (I had the same issue with AllPlan).Matthew wrote:It's not intuitive out of the box, but if you work with it for 2-3 days it makes sense and feels good. No, you won't know everything by then, but it will be a comfortable product to use. There are ArchiCAD features that you need to take a few minutes to learn, Revit is no different.
I happen to know that is is quite intuitive to the people that wrote it. But no-one else that I am aware of.
2006-06-17 07:01 PM
Matthew wrote:Specially when form•Z's original selling point was its Architecturally friendly drawing approach.
2006-06-18 02:34 AM
Matthew wrote:
It was a few years back I heard that Revit users were falling back on AutoCAD for completion of their CDs. I don't know how true this was nor whether they were just lacking the necessary Revit skills (or personnel).
2006-06-18 05:53 AM
Dilbert wrote:so true...problem is is that Autodesk does NOT guarantee the data will be readable from previous releases.
it will only be the data that really matters.
2006-06-18 06:27 AM
RLC wrote:Well, Revit data has been readable between each release so far, also every version of AutoCAD and ADT have been readable for each new release (yet not always backwards compatable, but the data from previous releases has always been readable in the new version). I'm curious, does Graphisoft guarantee this? Technically AutoCAD's been able to read each previous release's data since the beginning.Dilbert wrote:so true...problem is is that Autodesk does NOT guarantee the data will be readable from previous releases.
We've done government contacts that insist on readable data for 10 years.
That immediately counted Revit out.
2006-06-18 10:41 AM
metanoia wrote:ha! you could be talking about archicad there . . .
My two biggest gripes about Revit are
- performance problems on large projects (yes, it can be offset by linking files, but files don't link as well in Revit as they do in AC)
- lack of freeform modeling tools
2006-06-19 12:32 AM
2006-06-19 02:38 AM
Dilbert wrote:RLC wrote:Well, Revit data has been readable between each release so far, also every version of AutoCAD and ADT have been readable for each new release (yet not always backwards compatable, but the data from previous releases has always been readable in the new version). I'm curious, does Graphisoft guarantee this? Technically AutoCAD's been able to read each previous release's data since the beginning.Dilbert wrote:so true...problem is is that Autodesk does NOT guarantee the data will be readable from previous releases.
I suppose I'm wondering why it rules Revit out? Is it because Autodesk doesn't provide anything in writing?
2006-06-19 05:30 AM
outofchaosaworld wrote:There is nothing that replaces SketchUp at this point of time.
What i would like is something that integrates the workflow better. I would rather not have a model run in parallel with the drawings. Obviously all of the BIM solutions will do that but i am intersted in which one replaces the Sketchup stage most successfully (if at all). I am also intersted to know which takes layering and drawing standards most completely out of the hands of the user. I need something which reduces the opportunity for error where possible.
2006-06-19 08:28 AM
