2006-03-15 08:07 PM
2006-04-28 02:50 AM
Matthew wrote:As a newbie in AC, thank you, thank you, thank you. I'm self-taught and rely mostly on books and a CD. I hadn't found a way to offset a simple line.
1. Select Line tool <L> (<> = keyboard input, capitals for clarity)
2. Centerlines crossing at intersection; click, click, click, click.
3. Edge of road: Offset tool <O>, spacebar click, <R>, <12'>
2006-04-28 05:59 AM
2006-04-28 07:46 AM
2006-06-13 09:22 PM
2006-06-14 05:16 AM
jocontreras wrote:1. I would not expect the cut wall to look different in the plan and the section. However, if the wall is lower than the plan cutplane, then it does not appear with any fill in the plan. That is done as it should be.
I recently having a little time off and started doodling with my new archicad 10. Im a little bit dissapointed.
1. Walls still cannot have different fills on plans and in sections (cutted walls)
2. In hidden line 3 d view (internal engine) one can still see the union between the slab and walls if you draw the slab up to the exterior face of wall (the way it is constructed in concrete construction)
3. No more ole. I used to attach excel sheets with information about code compliance and automatic dating in my sheets. Now I have to convert this information to pdf an extra step and bye to automatic updating.
4.One thing good is the automatic story levels in sections and elevations
I hope Im mistaken in some of these sad "discoveries"
2006-06-14 11:45 AM
2006-06-14 01:37 PM
jocontreras wrote:Jocontreras:
2.Correct me if Im wrong. But if you have the adjoining faces of the same material (slab exterior face and wall exterior face, material- general) You would still have a line dividing these faces in the 3d internal engine and in open gl (see drawing)
2006-06-14 01:40 PM
2006-06-14 03:36 PM
2006-06-14 08:16 PM
