2008-03-21 03:20 PM
2008-03-21 04:17 PM
TangoGrandma wrote:Nope. See my response, 3-posts-back (and you might want to cut back on the coffee)
Anything about changing the node-range for the clean up though? Pending walls being on the same level vs. starting at bottom elevation where the top of the other ends?
2008-03-25 05:16 PM
2008-04-07 03:57 PM
2008-04-07 06:23 PM
TangoGrandma wrote:Select the object
Is there a way to turn off the auto-scrolling through objects that share one co-ordinate?
When I select a NODE at a multi-node intersection, the MOMENT I attempt to manipulate that object/node, it AUTO-SELECTS another one.
I've tried using the TAB in many different ways, but I haven't found a relationship that is consistent to WHAT EXACTLY the TAB does except allow us to SELECT the object in a multi-object area... but if one then clicks that node it goes to ANOTHER OBJECT without my having SPECIFIED that object.When using the arrow tool, if you have quick selection turned on (the magnet button) an object will highlight when you hover over the top of it. A little blue box will pop-up and tell you what it is. It also tells you if there are multiple objects under the node you are hovering over. To cycle through them repeatedly press the TAB key until the one you want to select highlights. Left click to select.
So how do I turn this off?
I ONLY want to select a DIFFERENT object, after I've specified the object, by clicking a control key (such as TAB again) -otherwise I'd like to set up my app to stay working on the object I'm editing -WITHOUT HAVING TO MAKE OR HIDE NEW LAYERS.
I noticed this week how many people are on here looking for help and it's a huge amount of users seeking help.I haven't noticed it being any busier than normal recently, possibly around one hundred posts a day perhaps, with over 70% being answers. (As a guess!)
That might be indictive of the software or simply of not enough of us finishing our tutorials. These issues don't exist in3dsmax, which just got picked up by AutoDESK which owns AutoCAD, Revit and all the rest.You reckon?
2008-04-07 08:20 PM
TangoGrandma wrote:Per 'the almighty' Lachmi Khemlani:
The quality of the documentation in ArchiCAD can now be rated as outstanding, particularly the Interactive Training Guide. I have yet to see such an innovative and effective approach to training in the entire CAD/BIM world—and the best part of it is that it is free! Graphisoft deserves plenty of kudos for making such a concerted effort to provide effective training as part of the application, rather than forcing users to rely on professional help to learn to use it.Apparently, GS is doing something right... Personally, I don't think there is any excuse for any new user over the past couple of years to not have completed the Training Guide.
