!Restored: pen sets and colors
Hi
How can i identify primary colors in the pens and color(model veiw), or do we have to settle for the number assignment?.or which number is primary blue,red green etc......
Similarly in the edit color dialogue box, what is the purpose of the custom color band ?,
i assume the basic color group cannot be modified or tampered with.
Thank you
Femi
7 Replies 7
Jere
You can modify each and every colour to suit your needs. In fact, in our office we have modified the first 8 colours to those that we liked.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Thanks, what are the numbers that corresponds with primary colors
Jere
In RGB (based on the additive properties of light), they are:
Primary:
Red: RGB(255, 0, 0)
Green: RGB(0, 255, 0)
Blue: RGB(0, 0, 255)
Secondary:
Yellow: RGB(255, 255, 0)
Cyan: RGB(0, 255, 255)
Magenta: RGB(255, 0, 255)
The primary colours as we're taught (based on pigment mixing) are Red, Blue and Yellow. The secondary colours are Green, Orange (RGB 255, 128, 0)and Purple/violet (RGB 128, 0, 255).
Pardon me to bother you,
it appears like addictive properties of light will come as a more applicable reference here than pigment base mixing for Archicad 11,(i stand to be corrected), i am particularly interested in locating these color: black, green,blue, red in pens and color dialogue box of Archicad.though i wish i am more sensitive to differentiate colors. , may be using a particular pre-define pen set as an example.
How do you relate (255,0,0) number combinations e.t.c. in identifing color form the 256 list ?.
Cheers
Femi
Jere
Using the standard ArchiCAD pen set (which I don't use) the primary colours are:
RGB primary colours:
Blue: pen 8
Red: pen 121 and 130 (pen 5 is close)
Green: pen 123
Black: pen 1, 100, 127, 140-150
CMYK primary colours:
Cyan: pen 124
Magenta: pen 126
Yellow: pen 122
Femi,
You seem to be thinking about this the wrong way round.
Each pen number is usually used for the same specific purpose on each pen set generally. For example pen no. 27 (on mine) is always for cut structural walls, pen 23 always for openings. What colour you want each pen is entirely down to the purpose you need it for.
If you need a pen set for drafting/modelling you would usually want each type of element to have a different contrasting colour. This helps you to see at a glance whether you are using the correct pen for the purpose, and clearly defines the different types of elements on plan.
When you want to print a plan, you should set the drawings to use a printing pen set that generally has most of the pens set to black. You would not generally use this pen set to draft/model with.
You can also set up different pen sets to highlight or emphasize any particular information that you want to convey. Maybe setting all the structural walls to be outlined in bright red, for example. This can be done by simply copying the printing pen set, and then changing the pen for the structural walls to red and increasing the thickness.
This arrangement gives a lot of flexibility in how things can be displayed without having to keep changing the individual settings of all the elements.
It sounds like you want to set up a high contrasting pen set for modelling purposes. Simply set up a pen set where the use of each of the pens stays the same but the colour is different. Simply double-click on any pen in the pen set to launch the colour chooser, and you can type in the RGB in the three boxes marked Red Green & Blue on the right.
My apologies if you know all this already . This is a fundamental part of outputting drawings in ArchiCAD, and you should have it absolutely clear in your head how it works before commencing any major work, as correcting it may be complex!
I hope the above ramble may be useful to you! Best of luck!
Pete,
Thanks for sharing that, one of the reasons why i ask the questions is that i want to identify the primary (unadultrated) colors in Archicad 11 as a reference point, most especially as i have preference colors for Building Elements in CAD, and i will prefer not to use non-primary colors (or modified colors) for certain purpose while thinking i am using primary colors ...........................
