Retaining Display Options
I have Section/Elevations markers selected as "As in settings" in the display options, together with Section Depth as "do not show"
When I change from the screen display between the Project Map and View sets, the sections default to "Normal" and "Show". I've save the file with the sections showing the way I wanted only to open the file latter and find the sections showing incorrectly.
How do I control the display settings to my choosen defaults.
I have no problem with any of the others.
Any suggestions. ?
Conrado Dominguez
AC8.1, XP Pro
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
4 REPLIES 4
Djordje
Conrado wrote:
How do I control the display settings to my choosen defaults. I have no problem with any of the others.
Redefine the views.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje wrote:
Redefine the views.
Yes, except that the views are generated from the Project Map plans, and it is there that the sections change. So, every time I change the plans, the sections default to the unwanted option, therefore I have to change the options in the views, before I "redefine"
I guess I have to somewhow work around this, meaning, wait until I am ready to plot and remember to make right the options display.
Conrado
Djordje:
I got it.
1. In the Project Map, define the Options.
2. Move to the Views
3. Highlight the view to modify
4. Select the display option defined in 1
5. "Redefine" the view.
Thanks for pointing in the right direction.
Conrado
Djordje
Conrado wrote:
I got it.
Mabruk!
Djordje
HP Omen
