mukster
Roof Composites not showing up
I'm putting in roof composites. Sometimes the whole composite shows up, sometimes parts are missing. It gets to be really annoying. Then, a few minutes later, the whole composite shows up
4 Replies 4
Can you post one or more screenshots that show the exact problem?
mukster
There is 1 3/8 Wood at the bottom of the composite but it's not showing up. This is a recurring problem.
Your Partial Structure Display is set to "Without Finishes", So it is not showing that 'finish' skin of Wood.
And the Partial Structure Display setting is stored in Views.
This is the reason why you may see the finish skin, but if you then activate a View with the "Without Finishes" Partial Structure Display setting, the finish skin will disappear again. The solution is to redefine your Views with the desired Partial Structure Display settings.
