Roof Connection
Cec
I've just started working in archicad 28 and have noticed that the roof sometimes connects slanted on one side. This is obviously not a very good look so I've tried to fix it without success. Anyone experienced the same problem? Why does this happen and how can I fix it?
Operating system used: Mac Intel-based 15.2
ArchiCad 28 - Intel based
MacBook Pro 2020 2 GHz Quad-Core Intel Core i5
Sequoia 15.2
6 REPLIES 6
Cec
I didn't have this problem in archicad 27 so idk
Sequoia 15.2
Cec:
Check the Roof Pivot Lines (there is an On-Screen View Option to make them visible) to see if they are parallel. Also, with the Roof Tool selected, you can select one Roof, then Command-Click on a border of the second roof to find their intersection if the Roofs are not parallel.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you! It worked for the smaller house, while the roof on the other one is still acting weird. I've attached a photo of the roof plan, I've tried the blue line on both of the vertical sides and it still looks the same
undefinedundefinedundefined
Sequoia 15.2
The roof is not a rectangle but a trapezoid, the bottom and ridge of the roof are not parallel to each other because of this. Therefore, a ridge runs up at an angle. Best start over with a perfect rectangular roof.
Apple M1 Max 32 GB Ventura
AC27
Cec:
Set your Working Units to their highest accuracy (Angle Unit to 4 Decimals, etc.) so you have the most accurate information. These do not affect the Dimension preferences for output.
Thanks for adding your Signature.
David
Cec
Thank you:)
Sequoia 15.2
Setup info provided by author
