mukster
Roof Edge Problems
I'm having a problem with my roof edges on a couple roofs. Most of the roofs I have are fine, Edge Angle: Vertical and Trimming Body: Pivot Lines Down.
However, there are a couple of roof places that have their edges at an angle, and I can't seem to get them to go straight. I've tried injecting properties from a correct roof and it doesn't work. All roofs have the same parameters that I can see, it's just these couple roof plans refuse to cooperate.
Dwight
When something like that goes bad it is usually expeditious to re-draw the problem elements rather than mess around with corrective measures.
Dwight Atkinson
David Maudlin
mukster:
Have you tried selecting one of the problem roofs, clicking one of the problem edges, then selecting the upper right option in the Pet Palette (Custom Edge Settings), then selecting Edge Angle: Vertical?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
