2006-06-19
11:44 PM
2023-05-23
03:29 PM
Rubia Torres
2006-06-20 05:27 PM
Dan wrote:To clarify... this is "clear as mud", I know.
Does version 10 offer the abilty to display walls across stories like the roof tool and objects???
2006-06-20 10:56 PM
2006-06-21 07:42 AM
AC10 DOES offer the ability to display walls across stories, but not in the exact same way as objects and roofs.DHURD said:
If you set the wall to "Automatic" and "Projected with overhead" it will display in stories according to its location, height and the cut plane settings of that view. I've got one wall just now that displays in three stories.
Set the walls you want to see to "Automatic" on the show on/Link to stories:This is all true, so sorry for my incorrect post.
Then on Document - Floor plan cut plane, set to show 1 story above and or below.
2006-06-21 09:16 AM
Link wrote:Exactly. What's needed at first is to separate the settings for the wall's Location(home story) , Where it's displayed, and How it's displayed.
Like Geoff said here the relationship between stories and the Floor Plan Cut Plane needs to be simplified. There's just too many variables.
2006-06-21 04:03 PM
2006-06-21 05:28 PM
Matthew wrote:Well, i think with the current possibilities of saving views with different layer combinations and other settings your wish isn't so far away, it's just that you can't have them open simultaneously like with S/Es.
The real simplification of this can only come (IMHO) when there are separate windows for Floor Plan, RCP, Enlarged Plan, etc..., each of which has its own settings and view options (all available as global variables to the GDL scripts of course). I too would like to see the current arrangement simplified, but there is only so far that this is possible under current circumstances.
2006-06-21 09:49 PM
Thomas wrote:Yeah! All that and so much more. I think it's probably coming in some form or other. The question will be how long it takes.Matthew wrote:Well, i think with the current possibilities of saving views with different layer combinations and other settings your wish isn't so far away, it's just that you can't have them open simultaneously like with S/Es.
For me the important reason to be able to open several floor plans (and 3D views) at once is to able to work om several floors/stories, to have an overview and a couple of detail views opemand activeat once, so can begin to draw someting in one and finish in the other, and to have different grids (also rotated UCS /user coordinate systems/ active.
Imagine being able to rotate a plan view for a project part that is at an angle to the rest, so you still can use all the present view-aligned orthogonal working methods in that part too!
2006-06-21 10:58 PM
Matthew wrote:I mostly agree. But whenever I say that the introduction of multiple plan views will challenge Stories as we know them I am treated like a heretic by the ArchiCAD faithful.
I think that, like other things such as layers, the complexity of this is largely due to the plan view window having to do so many different things.
2006-06-22 02:04 AM
ArchiCAD should take the giant leap from window per viewpoint to window per view.Amen!
2006-06-22 02:21 AM
Geoff wrote:From what I have seen we are more than mostly in agreement. We've gone on at great length about this before, so I won't belabor it here, but...
