Rod Jurich
Roof Tool Bug??
Has anyone been able to successfully drag a copy of a hole in a roof?
See attached. I have several holes made for roof light wells and the
only way to create copies is to place and drag poly lines then magic wand
them to make copies of the original roof hole.
Works correctly when cutting holes in the ceiling slab below the roof.
AC 11 Int (1114)
Rod Jurich
5 Replies 5
Dwight
Just tested it:
Using the arrow tool, click an EDGE of a roof hole. This should select only the opening.
Use either the pet palette multicopy or the Keyboard command and drag the selected opening. It's a copy!!
Dwight Atkinson
Rod Jurich
Dwight wrote:
J/..Using the arrow tool, click an EDGE of a roof hole. This should select only the opening.
Thanks DA, this is ok in the floor plan but all I get is nodes visible in 3D when selecting the problem roof.
And yes I've tried this on many of the other roof planes in the same project.
Tried all possible methods. Cannot get a dragged/multiplied copy of roof hole to appear in 3D as you do with the slab tool.
............ -o0o-
Before sending this I opened another file and all is ok, strange.
Stranger still is that when I create a new roof in the problem file, again all works as it should, go figure
Thanks again DA, just need someone to make me look harder.
The attached shows same result. No need for anyone else to waste their time testing. Gremlins
Rod Jurich
Rod Jurich
One final comment.
Tried the syringe to take up the properties of offending roof, then injecting same roof and all works fine again.
Try doing that with pen and paper
Rod Jurich
Dwight
What is that sympathetic yet exclamatory epithet the Australians use?
"Bugger!"
Dwight Atkinson
Rod Jurich
Dwight wrote:
/....."Bugger!"
Rod Jurich
