Roof and rafter
Can someone explain how to cut out the roof this hole? (the second roof section)
Eaves and roof at the ends do not come insulation, how to solve it?
Eaves end is this rafters like in picture. how it's made?
I hope anybody could understand what I thinking.
Best regards,
Jaano
36 REPLIES 36
Erwin Edel
Barry wrote:
Erwin wrote:
Barry, if you select the roofs and use Merge Elements, the lines will not appear in plan either.
Works with shells and roofs with shells. (and some more stuff)
Thankyou Erwin,
Even us oldies can learn something new.
I'm pushing twenty-seventeen (also known as 37), so not exactly fresh out of school anymore either!
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Erwin Edel
I still model ceilings seperately now and then, even with merge. Sometimes it just is more convenient.
I am a firm believer in there not being one definite solution for one single problem.
www.leloup.nl
Windows 10 Pro
I gave some of the layers different name and now layout book i dont see roof tiles, rain gutters, what is problem?
The view you used from the View Map has a certain layer combination used in its settings.
You must update that layer combination with your new layers or create a new layer combination and set that to be used in the view settings.
Never use a layer combination that says 'Custom'.
Same applies to anything else that shows as 'Custom' (pen sets, MVO schemes, etc.).
Ok, its helpful, Thank You!
But, same question again, Where i can such Objects like nr. 1-8?
It is very important!
Don't really know how to make roof accessorys? I view many pictures in google where is used them solutsions, but how? Ladder, snow guard, etc?
Erwin Edel
http://bimobject.com/en/monier/product/jonakerpannan
This might have what you are looking for.
Roof accessoires is an addon available from the ArchiCAD help menu download link. It also comes with a library, that will be installed on your harddrive in the ArchiCAD folder. You need to load this library along with the library you download from bimobject.com
www.leloup.nl
Windows 10 Pro
