2016-08-24
12:32 AM
2023-05-23
02:20 PM
Rubia Torres
2016-09-20 09:00 AM
Barry wrote:I'm pushing twenty-seventeen (also known as 37), so not exactly fresh out of school anymore either!Erwin wrote:Thankyou Erwin,
Barry, if you select the roofs and use Merge Elements, the lines will not appear in plan either.
Works with shells and roofs with shells. (and some more stuff)
Even us oldies can learn something new.![]()
2016-09-20 09:01 AM
2016-09-21 07:07 PM
2016-09-22 03:27 AM
nojaano wrote:The view you used from the View Map has a certain layer combination used in its settings.
I gave some of the layers different name and now layout book i dont see roof tiles, rain gutters, what is problem?
2016-09-23 02:16 AM
Barry wrote:Ok, its helpful, Thank You!nojaano wrote:The view you used from the View Map has a certain layer combination used in its settings.
You must update that layer combination with your new layers or create a new layer combination and set that to be used in the view settings.
Never use a layer combination that says 'Custom'.
Same applies to anything else that shows as 'Custom' (pen sets, MVO schemes, etc.).
2016-09-30 02:32 AM
2016-09-30 10:26 AM
