‎2025-02-03 10:23 AM
More a wish / feedback probably. Or have I missed this somewhere? Then please let me know.
I wish it was possible to have different angles on a pitched roof.
I find it way to much complicated to test out different roof angles.
		‎2025-02-03
		11:10 AM
		‎2025-02-08
		11:00 AM
Hi!
Have you tried with multi-plane-geometry? It seems to me that it would help, at least with the second part of your question, with multiple angles.
‎2025-02-03 11:33 AM
Hi, thank you for your answer. I've tried the multi-plane-geometry and adding a negative angle, (minus before the number) but that did not work out.
I guess my second question was not very well communicated. I want the red/orange solution.
		‎2025-02-03
		11:39 AM
		‎2025-02-08
		11:01 AM
Oh, then I think you are referring to Roof Edge Angle. You can have it perpendicular, vertical or custom.
The toggles should also be available when selecting the roof.
Unfortunately, I don't think you can have asymmetrical angles on the same roof, you will have to make two of them with a common ridge.
‎2025-02-03 11:42 AM
I thought so, but thanks for your response. Maybe one day in the future this will be possible 🙂
‎2025-02-03 11:45 AM - edited ‎2025-02-03 11:47 AM
That is an easy task. Select a first roof and control+click on the edge of the second roof you want to merge. Than repeat the procedure for the second plane.
‎2025-02-03 11:56 AM
Aha - thanks a lot, that worked fine 🙂
(I still think, though, it should be possible to do this using the pitched roof and just type in angles)
‎2025-02-04 01:20 AM
You can just type in a new pitch and it will alter from the pivot point (blue line) - for single plane roofs.
The plan outline will remain the same, so if both are the same pitch, there should be no need to re-trim roof edges together.
But if different pitches you will have to re-trim as the ridge position will move.
You can also stretch in section.
Single roof planes ...
And multi-plane roofs are a little different...
You can't type individual angle for each plane of a multi-plane roof, but you can move the ridge with the pet palette.
‎2025-02-04 02:54 AM
You can click on the Reference Line
‎2025-02-04 03:23 AM
Yes, of course - custom plane settings.
I was looking in the overall roof settings where you only see the default roof pitch.
In my defence, when ever I have any type of non-symmetrical roof or roof planes at different heights, I always go to single roof planes.
