Roof plan question
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-03-29
11:34 PM
2023-05-23
03:20 PM
Rubia Torres
Is there a way to generate a 2D vector line roof plan in Archicad? I used the top view axonometric window which is exactly what I wanted - but it's a bitmap. The reason for doing this is to import the drawing into Autocad. Thanks in advance for your help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-03 01:33 AM
For those of us who don't know, what problem does SEOing cause in a DWG export?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-03 01:43 AM
Dwight wrote:SEOs won't show correctly in ArchiCAD's plan window, let alone in AutoCAD!
Link:
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-03 02:27 AM
It is fast, simple, and a very useful tool for a new user to know about.
Creating a seperate file of any type and configuring it for import to AutoCAD is not nearly as fast as Copy and Paste, or Drag-n-Drop,
and you don't need to know anything at all about how to set up the .dwg translator.
There are several advantaged to using the Copy method.
One of which is that it will open up the 3D Copy Options window so you can control what you want to see, how you want to show it, and get rid of the redundant lines before you add it to the AutoCAD drawing.
There may be any number of reasons why he wanted to use the lines showing up in his 3D view of the roof rather than the lines showing up in his roof plan.
Also, perhaps he didn't want to take the time to tweak his roof plan to look as he wants it to show up in AutoCAD.
Orthodoxy with ArchiCAD modeling is seldom implemented to its fullest potential because in reality, it is seldom useful or necessary.
Perhaps the new user has already discovered this and was looking for a short cut.
There is never only one way to skin a cat. Especially with ArchiCAD.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-04-05 06:30 PM
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
