2023-12-09 09:48 AM
i select my roof go to Design extras,Roof accessories access the roof surfacing tool select the roof I want click ok and nothing happens,the roof surface doesnt apply
2023-12-09 05:00 PM
? Perhaps you forgot to add the Acessories Library ?
2023-12-11 03:16 AM
Are you trying to use a a multi-plane roof?
You need to split it into single planes.
2023-12-11 07:30 PM - edited 2023-12-11 07:32 PM
It can't be that. There is no Roof Surface to select if you have not added the Accessories Library. However, reading your method carefully, I see that you might be disabling the Roof Surfacer. Your description says: "i **select my roof** go to Design extras, Roof accessories access the roof surfacing **tool select the roof I want** [ooops - you just disabled it when you selected the roof the second time] click ok and nothing happens, the roof surface doesn't apply" Or did you mean you selected the Roof Surface you want - then clicked ok. ?
