Roof trimming beyond the Pivot lines when trimming bodies are set to pivot lines.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2024-07-05
05:28 PM
ā2024-07-07
10:19 PM
I have two multi-plane roofs. The upper roof trimming bodies are set to pivot lines. However, when I do the SEO subtract w/ downward extrusion it cuts the roof below at the contour lines. I can't seem to get it to behave as advertised. The screenshot included shows the Trimming body and you can see the hole in the roof below is way to big. Thanks for any insight. Sorry in advance if this topic has been covered, I didn't find it.
Operating system used: Mac Intel-based Ventrua 13.2
ā
ArchiCAD 26 on 27" Mac
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2024-07-09 02:37 AM - edited ā2024-07-09 02:39 AM
@Ivan Myers wrote:
For some reason thought I could punch a hole in the roof below using the pivot lines of the roof above. I'll use a different method.
Thanks
You can if you right mouse click > Connect > Trim Elements to Roof/Shell.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2024-07-06 11:50 AM
SEO does not use the trimming body.
It uses the entire element.
Only the right mouse click Connect > Trim options se the trimming bodies.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2024-07-08 10:44 PM
Ok thanks,
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2024-08-29
07:19 PM
ā2024-09-01
12:35 PM
By the way thanks for the help on this. So when I use trim to roof, the intersection point of the two roofs is the color of the cut fill. See attached.
I'm not sure what is going on. Basically have two cross gable roofs intersecting. Why is this so difficult?
Thanks
