Rotate Label
fuzzytnth3
Does anyone know if it is possible to rotate the Label text for an "automatically labelled" element?
The attached file has most of the automatically labeled elements with the text reading horizontally but there are a couple of items that have the text rotated 90 degrees.
I just can't seem to find away to rotate the text in the label object settings.
Thanks in advance
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
4 REPLIES 4
Djordje
Not in 7.
Yes onwards.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
i not sure if it's my computer or what, I can't 'enlarge' the image. I received a 'water droplet' sound when I clicked on the image.
fuzzytnth3
The image file seems to work for me ok. It's just a jpeg nowt fancy
fuzzytnth3
Got it to work now by adding a parameter to the Label object to rotate the text 90 degrees when I want it to.
If anyone wants a copy let me know
